useage problem
useage problem
Hi, wondered if anyine else has seen this issue, I have just gone into my new billing month, but according to the show my useage, My paid for is 88kb, Free Useage is 1.73Gb!!!!!!!
As I am not paying for it, its not too much of an issue, but according to the useage in detail, I have only used 96Kb. Suspect this is a bug of some description, but would welcome some clarification. I have not raised a ticket as I think it is a bug, but will happily do so if needed.
1 REPLY
Plusnet Staff
Plusnet Staff
useage problem
I suspect that it's because your billing date is today. VMBU doesn't completely reset dead on midnight instead a script runs as part of the billing run which processes the reset and fills in the archive usage. This normally happens a couple of hours after the billing notification is sent. If you check it this evening it will show the correct amount.
