upload
upload
Hi i have asked this numerous times with no reply so thought id start my own thread
Can anyone please tell me why my upload speeds are so slow
James
upload
Is your connection idle at the time of running the test? Any other activity could potentially reduce the available upload speeds.
upload
Hi yes everything is switched of firewalls the lot
have just completed another test to make absolutley sure
any ideas
This is an expensive internet connection at 30 pounds a month
thanks
James
upload
Out of curiosity, have you tried rebooting your router?
upload
Will do it now but i have not had decent upload speeds since the 22/11/2006
and it has been re booted numerous times since then
James
upload
It's definitely a pretty odd fault, and there would be nothing at this end preventing your upload speeds. We also never hit our peak amount of upload traffic on our centrals either, so it's not a restriction at that end.
If it is a wireless router, I would definitely have a look at ensuring that it is secure, just in case.
upload
Erm, and if you use a Laptop with a Centrino processor, the power saving 'features' have been known to cause lower throughput.
Clutching perhaps at straws a little - perhaps you could explain briefly your set-up?
upload
LOL it gets worse
this is after a reboot my router is secure and am not useing a laptop my stable rate is 1500 at the moment
i could not use internet last night it was that slow
please help
James
upload
I'm guessing your wiring is like:
Computer ---> Router ---> Filter ---> Master Socket?
upload
yes thats right
James
upload
Do you have a spare microfilter lying around? It's a long shot, given that you download speeds are okay, but I'm running out of ideas, fast.
upload
Yes courtesy of plusnet barand new will try now
upload
pings loads better
download speed better
upload is still terrible
James
upload
Well, that possibly suggests that you had a dodgy microfilter and at least it has improved your speed and latecy.
With regards to the upload speed, I'm afraid I'm out of ideas so am hopeful that someone else might have some!
upload
I hope im not in for another night like last night
