upload/download pipes
willhome
i believe i know the answer but i will ask anyway.
with your 155mbps and 622mbps pipe lines.
does that means you could do 155mbps up and another 155mbps down on a 155mbps pipe or does mean you can do say 100down and 55 upHuh
http://www.kitz.co.uk/adsl/equip2.htm (at the end of the page)
For a 622Mbs pipe its 622Mbs one way and 311Mbs the other. A 155Mbs is less effecient than a 622Mbs so the speeds in either direction are much lower in comparison to a 622.
willhome
so couldnt we have a seprate upload limit to download limitHuh?
