upgrade
Slick
upgrade
as there are so many posts and none really answer me question il type it here,
when will i be upgraded to maxdsl?
exchange results are here,
Status: Green
Good News, BT have finished enabling this exchange for Max DSL products.
Products will be available from 31/03/06.
Speeds: Our test also indicates that your line should be able to support a potential ADSL Max broadband line rate of 6.5Mbps up to 8Mbps
ive also had an email saying that i am to be upgraded.
i use a router with built in modem so how can i check to see if ive been upgraded?
cheers
JJ
upgrade
If you haven’t use the queue jump facility.
When…. No dates yet but if you do the above it will be sooner rather than later
(starting to sound like a CSC answer !)
Modem/router…… What make ?
JohnH
JJ
upgrade
Sorry didn't see the bit about having been advised that you were going to be upgraded.
Check your tickets. Have PN put one there saying an order has been placed with BT
JohnH
Fixes: 8
Re: upgrade
Somewhere in your router interface it will tell you the speed you are synced at - if you can't find it post to say what make/model it is and someone will point you in the right direction.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Slick
upgrade
i havnt had any tickets for a while now,
how do i use the que jump facillity?
as for router im using a belkin wireless G modem/router F5D7633-4
and it was a pain in the but to set up.
JJ
upgrade
Connect to your routers status page
The sync rate (called Data rate on the status page) can be found at the bottom left under the heading ADSL and then Data Rate.
It’s page 23/24 of the downloadable handbook from http://web.belkin.com/support/
John H
