updated linksys router and connection details have changed
I have just updated my linksys router firmware and now my dsl connection is showing that a couple of settings have now changed. Interleaved is ON and dsl modulation mode is now GDMT I remember one of these reading as fast before.
I am sync'd at 7040 Kbps is it worth requesting interleaving to be turned off. I don't think I will gain that much.
Any advice on these changes and if's best to leave interleaving on or off would be much appreciated.
A
1 REPLY
g.dmt is the standard for uk adsl as far as i know.
you can't change interleave, it's set by BT. i believe gamers prefer it off as when on it increases latency (ping times) but left on it is supposed to improve the stability of your connection.
