trouble getting conected using plusnet :(
brettking24
Hi for a few weeks my conections hasnt been to good,at times it will conect but at others it wont,i notice somtimes when browsing etc my msn will log out and try to reconect and web pages wont load even though my pc says its still online.ive tried cutting of but when i try to reconect it doesnt work just get a error
any ideas?
im on 2mb bb
Hi there and welcome to the forums.
Sorry to hear that you are having problems.
When you lose connectivity does your modem / router stay in synch. I.E does the ADSL / Link light remain on and constant?
brettking24
not too sure
not too sure,will keep a eye on it.
prichardson
In addition, it would be handy to know the error number and message you get when attempting to reconnect.
Re: not too sure
Are there any christmas lights near you? If you are losing sync this may be the cause.
brettking24
well..
well its just happend agaian and i notice just the power light is on on the usb modem.
think the error msg is 721
somthing about cant connect to remote computer,strange as when i reboot pc it seems to be ok untill it cuts of again
if only the power light is on on your modem and not the sync light work through:
http://usertools.plus.net/tutorials/id/13
http://usertools.plus.net/tutorials/id/10
