syncing at 7392Kbps could this be a usb 1.0 limitaion?
any ideas on if i would get a better sync if i was using an ethernet modem or my usb modem on usb 2?
Fixes: 8
I'd be very surprised if USB 1.0/2.0 affected sync speed but not if it affected your actual speed achieved.
Routers can give better sync speed and all in all are a far better solution.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
kjaerligkatt
Re: syncing at 7392Kbps could this be a usb 1.0 limitaion?
Using a USB 2 modem isn't going to increase your sync speed per se. The speed of your USB port only determines the daterate between the modem and your PC. The sync rate is the locked datarate between your modem and the outside world Wink
AFAIR USB 1.1 was spec'd up to 12 Mbit/sec, so would handle max ADSL rates much of the time (nothwithstanding other devices competing for USB bandwidth).
A different / better modem may achieve a better sync rate due to better / more tollerent design, and that could be USB or router based. In general the best ADSL routers will give better performance.
Regards, Neil
