sync problem
sync problem
ever since my line was regraded to 2mb from a 0.5mb it now sync's for about a second then looses it right away. dont even have a chance to log in
for the split second that it is sync'd it reports that it is connected at 2272 down and 288 up.
had a look at the log report from the adsl software and it shows that everything is with the 2mb limit except for the SNR which is showing as -4db yes that is right minus 4db.
could that be because it is only sync'd for a split second and miss reading.
before the regrade on sunday my line was perfect.
any info would be appreciated.
plus net are already aware and are trying to sort things out.
even if i have to put up with a 1mb line until this gets sorted that is fine by me
