sync bras and speed test results
ady
hey, jsut wondering, im synching at 2.1 - 2.3mb
which has given me a bras profile off 2000kbs
but on speed tests im only getting 1.4mb
is this like a limitation on my line ? or "should" i be getting the full sync speed/ only to be limited by the BRAS profile
thx ady
WHat speed tests have you tried - more than one I hope?
What speed do you get for HTTP downloads - www.btopenworld.com/speedtest/ and donload the 10MB file and see what the download speed settles at once it gets past 50% downloaded.
ady
for some reason, the plus.net speedtest doesnt work for me (use to)
ive tried adslguide.org and speedtest.net
from the BT 10mb file, i got 175kb/s
thx,
175Kbits or 175KBytes?
If 175KB then that is reasonable to good for a 2Mbs line.
Have yuo got firewall enabled (like norton or similar)? this will stop plus net speed tester working.
ady
i had zonealarm, but that was ok, i think it must be the router i baught, because i dont no how to config it
175KB/s *
i thaught i would be getting in the region of around 230KB/s
as 175KB/s was around* the same speed as what i got with a 1500 bras profile
thx ady,
ady
well i just checked on the BT site, and they have my IP profile as 1500k
even tho i just checked my plus.net stable rate, and that is set to 2000k
should i raise ticket ?
sophos9
ady
Your current broadband speed is 2000 Kbps
sophos9
The issue is BT's IP Profile set at 1500kbps, try na keep your modem on an synced at 2100kbps or higher for BT BRAS to up date, may take a few days
It seems plusnets MSR is correct... Wish mine was :twisted:
