suggestions
suggestions
DNS:
add a check box to the dns management page called reverse and if we then want that domain name to resolve we just check that box as atm if you want to reverse dns you need to ring up.
Gaming servers:
Increase not only the number of them but quality on the CS server I ping at about 200 using my adsl to plus net`s server I set up my own at work running on 100mb line and i ping at about 40 which is much more playable.
SMS:
Supply an SMS service for any customers who want to use it
Bandwidth:
Increase quotas to homepage usage or drop them 500mb a day isnt alot.
Domain name costs:
Decrease the cost of these £70 is abou £60 too much specially when you can go direct to registra`s and buy the mfor abtu £5 each i actually need about 10 mor but i wont be registering them through +net services.
refferals:
Can we have some GOOD banners please that actually encourage ppl to click on them.
theres possiably more but atm i cant remember what they were
RE: suggestions
Thanks for you suggestions. We are always looking for ways to improve our service as a whole and I do beleive we are already looking for ways to add SMS into our systems.
With regards to domains too, I believe it was raised and may be considered in the future to make some changes.
Chris
| Chris Rugen.....................................Unmetered & ADSL solutions
| Senior Technical Consultant..........................for Home & Business
| PlusNet Technologies Ltd............................@ http://www.plus.net
+ ----------- My Referrals - It pays to recommend PlusNet ----------------+
RE: suggestions
SMS is easy if you need help give me a ring I deal with the UK`s biggest SMS provider daily as its owned by a friend of mine
RE: suggestions
Hi David,
Thanks for the information.
Chris
