still shocking pings and slow speeds
Despite many people posting to advise Pn of slow speeds and pings nothing appears to have changed. I'm not using any games just normal browsing.
You are currently connected to the "Telehouse East, Juniper 3" gateway. This gateway is sometimes known as pte-ag1.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
E:\>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.224.124] with 32 bytes of data:
Reply from 212.58.224.124: bytes=32 time=25ms TTL=248
Reply from 212.58.224.124: bytes=32 time=26ms TTL=248
Reply from 212.58.224.124: bytes=32 time=27ms TTL=248
Ping statistics for 212.58.224.124:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 25ms, Maximum = 27ms, Average = 25ms
E:\>ping www.ntl.com
Pinging www.ntl.com [62.253.165.47] with 32 bytes of data:
Reply from 62.253.165.47: bytes=32 time=81ms TTL=111
Reply from 62.253.165.47: bytes=32 time=25ms TTL=111
Reply from 62.253.165.47: bytes=32 time=26ms TTL=111
Ping statistics for 62.253.165.47:
Minimum = 25ms, Maximum = 81ms, Average = 39ms
E:\>ping www.virgin.com
Pinging www.virgin.com [213.174.199.102] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 213.174.199.102:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
E:\>ping www.ati.com
E:\>ping www.microsoft.com
Pinging lb1.www.ms.akadns.net [207.46.20.60] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 207.46.20.60:
Reply from 212.58.224.124: bytes=32 time=24ms TTL=248
Reply from 212.58.224.124: bytes=32 time=23ms TTL=248
Minimum = 23ms, Maximum = 26ms, Average = 24ms
E:\>
Is this ongoing issue rerlated to the dns issues detailed here:
http://www.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=connectivity
can we expect to see this fixed soon.
A
amcclean:
Your pings look ok...
bbc.co.uk avg=25ms
ntl.com avg=39ms
virgin may not respond to ping, that's there choice
microsoft.com same as above
bbc.co.uk avg=24ms
My other spped tests all show latancy as being high.
A
That's the latency from the speed tester to you, they could be congested. With that particular speed tester I've noticed if you do two or three times in a row the latency can drop.
my worst speeds ever....
and my router stats....
Connection Speed 5408 kbps 448 kbps
Line Attenuation 30.0 db 18.0 db
Noise Margin 8.8 db 22.0 db
