static ips
chrisjon
static ips
hi, does any one know, if you move provider, do you take the static ips assigned to you, with you?
i have a block of 8.
regards
Quester
static ips
I'm fairly sure you wouldn't be able to keep your current IPs.
The IPs are assigned to plusnet.
static ips
Static IP's assigned in blocks to ISP's.
So no you'll have a different IP.
You'll also have to go through the process of requesting 8 from your new ISP as well.
static ips
Not every ISP will allow static IP addresses - check product specs carefully before you move.
rDNS might be worth considering as well.
