speedtest@speedtest_domain web site is down
Can anyone confirm if the BT speedtest web site that your asked to use durning the fault rasing process is currently down?
I've been trying over the last 2 hours and keep getting a system busy message.
Its not unusual for it to be unavailable, that's just how it is and you have to keep trying later.
Plusnet Staff
Plusnet Staff
Does the new BT Speedtest work for you?
http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
The old one which you access using the speedtest@speedtest_domain login is being withdrawn and replaced with the new one.
Cheers, but both are still giving the same busy message.
The reason why I'm trying to raise the ticket is I've been recently upgraded to a 8Mb connection but can't acheive more than 2Mb. I've ran the BT Speedtest twice yesterday with roughly the same results:
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 4000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5120 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1973 kbps
I belive I have a BRAS limit issue with my connection.
Cheers,
Sean.
Fixes: 8
What does https://portal.plus.net/my.html?action=stable_rate say?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Plusnet Staff
Plusnet Staff
Has the regrade only been done in the last few days? It looks like the new speed hasn't filtered through all the various databases yet and updated on our side.
I've manually changed this for you so if you disconnect and reconnect to allow the change I've made to take effect you should see a speed increase.
Cheers Dave !!
Support like this is the reason why I'm still with Plusnet after nearly 4 years!!!!
100% prefect result.
IP profile for your line is - 4500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 6528 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3855 kbps
Thanks for your help. Please feedback my positive comments about the support provided in the forums. It really does make Plusnet different.
Thanks again,
Sean.
