speeds
speeds
what happends then from midnight to 08:00am?, do we get faster speeds?
speeds
Between the hours of Midnight and 8AM you are in off peak time.
If you are on BB+ you will see slightly faster speeds for things such as P2P and Usenet etc as well as a 50GB limit.
If on Premier you will use the off peak SUP allowance.
On both accounts you will see faster speeds should you be managed in some way due to going over your allowance etc.
I hope this helps you in some way ( although I know its breif ).
Regards,
speeds
i am on premier 2mb account, and i am not on any managment restriction
