speeds down,
vic_newey
speeds down,
My speed for 1 meg is getting worse ,can't get back to the 960 or so I used to get.
tried all the usual tests to no avail .
17-05-2005 20:00:39 677.7
17-05-2005 20:00:10 736.9
17-05-2005 19:48:38 761.5
16-05-2005 21:01:11 892.2
16-05-2005 20:26:49 418.6
16-05-2005 20:05:46 340.7
16-05-2005 20:05:18 359.9
10-05-2005 22:41:39 921.8
10-05-2005 22:26:04 769.2
same problem
just got upgraded from 512 to 2mbs today started good speed to test good then sudenely drops:
Date Speed Achieved (kbps)
17-05-2005 21:02:26 809.8
17-05-2005 21:02:09 602.4
17-05-2005 21:01:33 531.1
17-05-2005 21:01:07 811
17-05-2005 21:00:41 494.7
17-05-2005 19:15:51 826.5
17-05-2005 19:12:41 961.1
17-05-2005 18:57:26 737
17-05-2005 18:49:52 1749.4
17-05-2005 18:49:22 1592.5
any body got ideas, could this be exchange problem it is on amber. But why would i get two good speeds at 1592 and 1749, then the drastic drop to 737. Even got down to my old speed at one point 494. On bb+ by the way. Or could it be somthing todo with regrade
speeds down,
17-05-2005 21:18:55 627.3
17-05-2005 21:18:52 656.3
17-05-2005 21:18:31 844.7
17-05-2005 21:17:09 954.5
17-05-2005 21:14:53 1459.1
17-05-2005 21:14:01 1609.2
17-05-2005 21:13:42 1662.7
17-05-2005 21:13:12 1424
17-05-2005 21:12:54 1629.2
17-05-2005 10:51:35 1933.7
Mine have also suddenly dropped this evening... (I'm 2mb)
speeds down,
1meg connection
17-05-2005 21:52:53 610.1
17-05-2005 21:52:23 613.3
17-05-2005 21:52:00 717.5
17-05-2005 21:51:34 715
17-05-2005 21:50:58 796.8
17-05-2005 21:50:33 710.3
17-05-2005 21:50:02 677.3
17-05-2005 21:47:33 771.3
Speeds are below my usual 930+
Reboot of router didnt make much difference
speeds down,
17-05-2005 22:37:24 1915.8
17-05-2005 22:34:00 1825.9
17-05-2005 22:32:56 1879
17-05-2005 22:30:49 1911.3
17-05-2005 22:28:08 1811.1
17-05-2005 22:26:18 1893.7
17-05-2005 22:25:32 1927.8
Thats more like it... But why the huge dip in connection for a hour?
speeds down,
lol mine has got worse
17-05-2005 22:49:55 625.4
17-05-2005 22:49:34 529.3
17-05-2005 22:49:01 601.1
niterider
speeds down,
im having the same problem my speeds are very low for a 2mb connection. I just did a BT Speed test and the results are bad you can see them Here
Can one of plusnet staff help me please Cry
LiamM
speeds down,
Not too bad here :
17-05-2005 23:06:14 1889.8
17-05-2005 23:05:54 1887
17-05-2005 23:05:39 1899.6
17-05-2005 23:05:22 1875.3
17-05-2005 23:05:05 1899.2
@niterider, have you checked your exchange status (Virtual Path) at http://usertools.plus.net/exchanges ?
vic_newey
speeds down,
at least I know its not just me, bit better now @ 948
niterider
speeds down,
Not too bad here :
It's green. Cry
speeds down,
I've just been upgraded to a 2MB service and my best speed so far has been 1400kbps. Worst has been 600. Seems to be up and down all day every day. What's up? Glad it's not just me, makes me think it's more of a PlusNet problem.
rapalla
its well within spec
I raised a ticket on Monday complaining of speed drop from 960 kbps to 800 kbps consistently over the last weeks. The plusnet comment was 'its well within BT specification'.......
I am still waiting for a resolution! Evil
speeds down,
BT's specifications appear to allow 400Kbps to be acceptable on a 2Mbps connection. I presume they mean acceptable to them because it won't be acceptable to customers -- who will simply go looking for a LLU service instead. If PlusNet wants to keep its customers it will need to have a serious word with BT about what is and is not "acceptable".
Simon
speeds down,
PR100 You are right. I am getting speeds barely better than when I was on 512 speed. Having 'the fastest sped your line can support' is not much good if you never achieve it!
