speedPC/Mac
camus
speedPC/Mac
Advice please
My speed has dropped to 2meg or less at times since connecting a new HP Pavilion, thinking line problems I reported it(all ok)Connected an iMac and speed increased to 6 on a good day router is Netgear DG834g v2.(networked wired)cables checked, swapped,port swap, returned to origonal ports.
I suspect my net card (integrated)how can I test?I tried fitting another nic (disable motherboard nic) not accepted,all returned to origonal settings.
Run with firewall ant anti-virus off,no change.
Easy answer use mac,but not always possible.
regards
speedPC/Mac
have you run full scans on your HP system for viruses / spyware?
camus
speedPC/Mac
Checked with Ad-aware
Spycatcher
AVG free
All showing clean
All drivers updated
Windows updated
Line check BT to-day giving speed of 3.7. Suppose speed would increase if I only used Mac for 3 days, then back to usual, although I understood the speed related to the router and not machine specific,thats why I suspected the nic .
regards
Fixes: 8
speedPC/Mac
Is the MTU in your router 1500? If not give that a go.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Plusnet Leader
Plusnet Leader
speedPC/Mac
Can you complete a BT Speed Test? This will show both your line profile and your sync rate and may shed further light on the problem.
Fixes: 8
speedPC/Mac
Err...
How would a low IP Profile slow down a PC but not slow down a MAC on the same connection?
Plusnet Leader
Plusnet Leader
speedPC/Mac
My bad Shockedops:
I misread the question!
Have a look at this link for some tweaks that may improve the speeds.
camus
speedPC/Mac
Line test from BT today ,
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3753 kbps
MTU is 1500
Line attenuation
D/stream 32db u/stream 9db
noise marg. 6db 25db
thanks for the interest shown.
camus
speedPC/Mac
My bad Shockedops:
You are a very very nice man.
Did as you asked....results
Router mtu 1500 unchanged
ran prog saved result as 1450
Plusnet speed 3.25 happy puppy
speedtest.net choose london server 6.3 wet puppy
return retest plusnet 4.95 damp but v/happy
many thanks
What will I do if it goes above 6...........
