speed!!
speed!!
I have PlusNet Broadband Plus - Up to 4Mb with a min of 2MB, which by using plusnet speed checker i have yet to reach..anyone else finding this??
Pondering why i am paying 25 pounds for this. Evil
speed!!
how much less than 2Mbit are you getting?
Re: speed!!
there's only plusnet who can justify that question - no one else can
Re: speed!!
what do you get on the BT checker?
http://usertools.plus.net/tutorials/id/27
speed!!
also the anal, angry response:
you will never reach 2MB on a 2Mb line :twisted: Wink
speed!!
1950ish is the fastest i have ever had, not quite 4MB.....done loads of speed checks too.
speed!!
you will not have been supplied with 4Mbps. it is not available yet. the up to 4Mbps deal involves supplying you with 2Mbps until 4Mbps is available.
1950kbps is a good speed for 2Mbps.
for reference here is my adslguide speedtest result
http://www.adslguide.org.uk/tools/speedchart.asp?id=f5a39e1b105178f57a5d46c5b8a
it is important that you realise 2Mbps does not equal 2MB/s. there are 8 bits(b) in a byte(B). therefore 2Mbps is roughly 250KB/s
