speed usage notice
mcgoo
speed usage notice
from pn own portal my usage and speeds.As you can see i am well below 4gb per month and the earlier months average speeds were 927kbps to..............98kbps now.Apparently i am expect to take less so as payg and premier can zoom around the internet whilst i slither and wait for 7 hours for a 215kb file to download.I have requested a mac code and am lucky enough to have migrated in therefore dont have charges and when they want their months notice payment i shall tell them Dont be sily didnt you know that when i signed up expecting 4gb and 8mb speed and didnt get it because you gave it to the higher paying users then you should have know that only the higher users would pay the months notice fee....silly pn
speed usage notice
can you post your Modem stats.
Synch speed. and have you done a BT speed test?
mcgoo
speed usage notice
Modem bt voyager 100. bt speed test doesnt regonise my user name and how do you find your sync results?
Plusnet Staff
Plusnet Staff
speed usage notice
The following page:
http://www.kitz.co.uk/adsl/frogstats.htm
lists how to get the stats on most modems including the Voyager 100.
Fixes: 8
speed usage notice
http://www.kitz.co.uk/adsl/frogstats.htm#anchor8
Damn - Dave beat me - but at least I linked to the correct place on the page! Wink
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mcgoo
speed usage notice
dont know if this is it but i get.
data rate transfer 128 recieve 5952
line rate 192 and 6496
Zathras
speed usage notice
I think they want Line attenuation and snr margin figures.
mcgoo
speed usage notice
dont know where or how to get them?
Zathras
speed usage notice
Did you follow the instructions on that website?
speed usage notice
With reference to the BT speedtester, try the following username format <PN username>@plusdsl.net
Let me know if you have any luck with that.
mcgoo
speed usage notice
Home Image not loadedTesting Image not loadedResults Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 135 kbps
DSL connection rate: 320 kbps(UP-STREAM) 160 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 74 kbps
If you wish to discuss these results please contact your ISP.
i do and they dont care as im greedily expecting 4gb and near 8mps which is the contract i signd up for
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
see above comment
So if this tells you anything id ont know but is the same speed i have been getting all day from various speed testers
N
mcgoo
speed usage notice
heres todays three tests,
15-02-2007 19:20:02 38.4
15-02-2007 14:48:20 127.4
15-02-2007 01:36:14 130.1
down to an impressive 38.4................ Evil Evil :twisted: :?: :arrow:
Plusnet Staff
Plusnet Staff
speed usage notice
It looks like your line is sync'd at 320kbps, because of this BT have set your throughput speed to 135kbps which is why you are seeing the speeds you are seeing in the speedtest.
Something between your equipment and your local exchange is causing your sync speed to reduce. Looking at your speed history it seems to be dropping down quite regularly and then going back up to around 6Mbps over the last 2 months or so.
To within about an hour the most recent decreases happened around
05/02/2007 19:30:16
29/01/2007 23:46:02
26/01/2007 18:49:55
19/01/2007 10:24:46
01/01/2007 12:41:07
Do these times tie in with anything that could be causing interference? Something like central heating or some kind of lighting or a microwave or anything else like that, or maybe making/receiving a call or sending a/receiving a fax?
I'd also suggest to take a look through this to see if anything helps:
http://usertools.plus.net/tutorials/id/13
mcgoo
speed usage notice
05/02/2007 19:30:16
29/01/2007 23:46:02
26/01/2007 18:49:55
19/01/2007 10:24:46
01/01/2007 12:41:07
No, so how to i get the sync speed up ?as i have had bb for around 4 years and do not want dial up speeds i am recieving at the moment.?
All i want is 4gb, and a reasenable speed.If i reach 4gb then by all means slow me down to the snails pace i am getting at the moment as i am paying for this service is it so much to ask for?
