speed test
speed test
connection is below 1 meg when i run a speed test and it says my product should be quicker than should change the connection settings but change them to what? and how?
speed test
which product and are you maxed yet?
If so how long have you been maxed?
speed test
thanks for speedy reply
i haven't been maxed yet that i am aware of. i am pretty new customer (4weeks) so i wouldn't expect to be maxed . product is broadband plus up 8meg
speed test
Now I think about it, I'm not 100%, but I thought all customers who joined after the rollout of Max were automatically Maxed.
Are you just using the Plusnet Speedtest?
Because sometimes its unreliable your best bet is to try BT Speedtest during early morning time.
It may also be contention on your line, or your line stats are bad (find those in your router stats)
speed test
i had a look at the bt site but that is way to complicated for me. i don't fancy changing settings then not being able to get back to normal.
as for the router i don't know what to look for or where to look.
i will post my speed test results, as you can see pretty up and down but this week has been very slow.
Date Speed Achieved (kbps)
12-06-2006 19:51:49 70.8
10-06-2006 00:02:01 229.8
04-06-2006 09:55:31 60.3
02-06-2006 23:01:14 344
02-06-2006 15:19:32 101.3
02-06-2006 15:10:50 68.5
31-05-2006 20:23:03 216.2
30-05-2006 18:26:53 409.4
27-05-2006 14:12:39 426.5
27-05-2006 09:33:46 283.9
27-05-2006 00:03:26 639
26-05-2006 22:57:54 829.4
26-05-2006 19:23:28 276.5
25-05-2006 10:57:09 397.8
