speed test weirdness
bigtim
anyone having trouble with the speed test tonight as mine says I'm running at 0,so i notice the bit about turning the Norton firewall off and try again and it jumped to off the scale to over 196000 kbps.Is this just with having norton in.
The PlusNet speedtest can be erratic at times and report 0 and high numbers. No real cause has ever been found why this happens. Normally you can repeat the test a bit later and you get sensible results.
Make sure the test is not using https:// as the URL (remove the s and try again) as that can cauese wild fluctuations.
Norton based firewalls and some others are known to conflict with the PN speedtest hence to recommendation to disable them if the test is not working.
Yup I ran a speed test last nite,of the scale!Im on 2mb premier,but when I used bulldog, adslguid,bandwidthplace,and bt,I was only getting speeds in the regin of 1mb and my download speeds confirmed this,plusnet cant cope after 1900hrs at nite every nite.
