speed optimisation
speed optimisation
after running speed tests, force 9 say that my speed is below what I should get and that i should check out their speed optimisation pages. the link given does not work. a search has proved fruitless so far. any ideas?
1 REPLY
speed optimisation
there is a bt test login that you can use
BT Broadband Speedtester
follow the instructions on their website, as you will need to disconnect from F9 and connect to BT for the test
regards
mike
