speed issues
speed issues
i was wondering if someone can help me
i finally got upgraded to the upto 8mb package on 27/12/06 after 8 months and then the same day i couldnt connect
this was fixed on the 31/12/06 but since then my line speed is getting slower and slower and i am now only connecting at 768 kbps
is there a initial running in period that i should be aware of as i hoped that i was finally getting somewhere and that i might finaaly have a decent connection speed but at the moment it looks like i will be back where i started on a half meg connection
alankay
speed issues
Yes a running-in period of 10 days, see this link
http://portal.plus.net/support/broadband/network/upto8Mb.shtml
Also, do a BT speedtest to get a bit more information about your line.
James
speed issues
There's an initial training period of ten days once upgraded to Max.
Do you know what speeds you are syncing at? Have you run a BT Speedtest?
speed issues
Hi
Yes i ran a speed test and it came back saying my line speed was 500 kbps
so i just wondered if anything had been reset as when i joined in april it said my line was 2meg capable but because of upgrade problems i didnt get upgraded until the 27/12/06
then it connected and sync'd at 2.2 meg then i had a problem that i couldnt connect as the line was connected at the local exchange but couldnt authenticate with the isp
this was sorted on the 31/12/06 but like i said the sync speed seems to be getting less and less so i just wondered if bt etc had re-set the connection or something
i am currently at work but if screen shots etc would help then i can do them when i get home
James
speed issues
Are you able to see your current sync level?
speed issues
unfortuneately no i wont be home till 6pm ish
James
speed issues
Just checked from here.
Sync isn't great at 768kbps, but this is subject to change. I'd try changing filters and plugging into the master socket to see if this offers any improvement.
speed issues
I will change the filter when i get home and it is already plugged straight into the master socket
what else should i be looking at as im not 100% sure what all the snr margins etc mean
James
speed issues
Basically, with the current sync speed you are getting you will not get speeds over 500kbps. I want to see if the changed filter leads to an improvement in sync speed - which should lead to an improvement in connection throughput within 3 days.
speed issues
ok when i get home ill check and post the speeds i am getting and then ill change the filter and see what happens
and thanks for your help so far
speed issues
right i have had another look at the settings and everything seems to be as it should be
but these are the results im getting
Connection Status
Online Time 19:32:26
Data Transmitted 1613462329 bytes
Data Received 1443383266 bytes
Downstream Speed 768 Kbps
Upstream Speed 448 Kbps
DSL Status
Operational Status: Showtime
Counters Local Remote
Intrlvd Fast Intrlvd Fast
FEC: 2059683 0 1693 0
CRC: 1442 0 199 0
NCD: 0 0 8 0
OCD: 12 0 - -
HEC: 1102 0 141 0
SEF: 0 10
LOS: 0 11
Failures Local Remote
NCD: 0 0
SEF: 1554 0
LOS: 0 0
LCD: 1527 0
DSL Parameters and Status
Vendor ID: 00B5GSPN
Revision Number: Y1921a
Serial Number: 123456789abcdx
Local Tx Power: 12.13 dB
Remote Tx Power: 14.78 dB
Local Line Atten.: 58.0 dB
Remote Line Atten.: 31.5 dB
Local SNR Margin: 11.5 dB
Remote SNR Margin: 14.0 dB
Self Test: Passed
DSL Standard: G.dmt
Trellis Coding: Enable
Framing Structure: Framing-3
Config Data Up Down
AS0(kbps): - - 768 0
AS1(kbps): - - 0 0
LS0(kbps): 448 0 - -
LS1(kbps): 0 0 - -
RValue: 16 0 16 0
SValue: 8 8
DValue: 4 4
James
speed issues
Filter change?
speed issues
Yeah i changed the filter but so far it hasnt made any difference
James
speed issues
Nope, apparently not.
I think we're going to have to wait until the end of the ten day period before we're able to do anything. I just wanted to rule out faulty filtering.
speed issues
ok thanks for the help
i am willing to try things to rule them out
i have got screen shots of before the problems but i cant seem to get them onto a post
