speed issues
speed issues
was having a game of BF2 as plusnet said it was fixed
played ok for around 5 minutes then got "there is a problem with your connection"
went straight on to plusnet and done a couple of speed tests,
I am on 2Mb premier speed tests as follows
428.3
378.8
then a BT speed test
1780 kilo bits per second (Kbps)
then back to plus net
1845.
Whats going on
speed issues
Contention
speed issues
Have a look at the Battlefield 2 Connection Problems at the link below
http://portal.plus.net/central/forums/viewtopic.php?t=37485&start=645
You are not alone my friend....you are not alone!
speed issues
try visiting the Broadband Help forum and checking how many speed issues are being raised there. Then you might 'smell the coffee'....
speed issues
just done it again only lost synch this time
well if its contention (which shouldnt cause disconnects)it must be at plusnets end because BT speed test was ok
I am well aware of the BF2 issues going on at the moment
however that would not drop my line speed.
speed issues
if your losing sync then its a fault with your exchange
speed issues
that wouldnt explain low speeds with plusnet would it?
I grant you that may be a seperate fault /issue
speed issues
There has just been a service staus report saying that a recent speed problem has been fixed.
speed issues
have you checked your exchange at http://usertools.plus.net/exchanges/ for issues or VP issues?
___oDiN__
speed issues
sync loss is usually home wiring/modem/router or exchange issues and isnt plusnets fault
if your experiencing speed issues as well id look to your exchange as it may be the cause of all your problems
speed issues
yeah John just noticed the service status issue
I suspect that was it as seems ok now
Ill put the synch loss down to a glitch somewhere
cheers all
speed issues
Thats funny, as for most of the afternoon/earlyevening I was getting close to what I should be getting bandwidthwise (25K/sec upload).
Now, still inside my 'clean to' period, so unmanaged (in theory), uncapped (in theory), I'm getting (quick glance after reading the service anouncement) 1.6K/sec upload 1.4K/sec download on p2p.
I knew it was too good to be true.
speed issues
Hell, you just inherited my connection speed!
