speed complaints part II
H
- ithought id start this thread up again as the previous one closed today at 33 pages
can i have my details checked plesae bT speedtester result
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2267 kbps
but rated at 2,500 currently on the plusnet page
thanks
dave
James
I can't see anything on a Delta report, but I'll take your word for it and bump you up to 6500kbps.
Plusnet Staff
Plusnet Staff
Looks like the data's just changed on BT's side, should filter through anytime to our side. Once it does the figure on the portal will update, you may need to disconnect and reconnect for that change to take effect.
James
Although it's already been done, so I won't bother Wink
james...
my god thats awesome support!!!
i'll rebbot the router !!
I have a similar problem. BT speed tester result:
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1893 kbps
but rated at 2,000 currently on the plusnet page
Plusnet Staff
Plusnet Staff
I've updated the speed profile for you, it should now show as 8000kbps on the portal. You may need to disconnect and reconnect for the change to take effect.
That was a super fast response, thanks.
Craigiusmaximus
I have same issue
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3808 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1745 kbps
look at my sig for previous sync
Plusnet Staff
Plusnet Staff
Looks like the speed we've got on our side matches the BT data (both 2000kbps). There's a fault open with BT, but so long as the line sync speed remains stable the throughput should go up automatically within 3-5 days.
Craigiusmaximus
Thanks for that dave just want my old sync and speed back.... Cheesy
James
Craig - I've updated your ticket.
Craigiusmaximus
And back to you james thanks for getting back to me on this one. Cheesy
James
Cheers Craig.
