smart deal
smart deal
hi
i understand that the offer is due to end i feburary
couple of ?
if i upgrde to the 10gb deal currently £17.99 with 4gb does the price of £19.99 stay or is this price a limited time ie for first 3 months
are there any other limits applied to this package that i need to be made aware of or is it simply the same as what i have already got with increased usage
do i have to register for plustalk even though i dont use it, as it includes free plustalk
prichardson
smart deal
As this is a pays as you go product, there is indeed a limit to this of 10GB. However, you can pay for more usage at the usual £1 per GB pre-paid, or £1.25 paid in arrears.
You remain on the £19.99 deal for as long as you wish to, even it it is withdrawn from new sale. However, if the offer is withdrawn and you wish to change products, there is no way to move you back at a later time.
There is no way to move you to the £19.99 without PlusTalk. However, this does not mean you have to make use of it, but it will be there should you want to.
Kind regards,
smart deal
well i decided to upgrade which has been completed succesfully
had a look at my contact us where it is says upgrade complete etc, at the bottom was
Components removed: PlusNet CBC ADSL 2000 Dialup.
Components added: Plus.Net CBC ADSL 500 Dialup.
just curious what that means ?
JonathanW
smart deal
That's just some backend changes on your account, and doesn't have any effect on the way things work. Similar things happen whenever you change account type, as its just the system making sure that everything is reperesented in the way it should be.
smart deal
many thanks
