slow header download from astraweb (3kB/s)
Currently running at abtout 3kB/s
Using Forte Agent, connected to europe.news.astraweb.com
What speeds are others getting at astraweb?
Edit: I am on premiere option 1, and have a 6.2Mb/s result at speedtest.net
Mand
Are all other protocols OK? Which gateway are you on? Have you tried connecting to a different gateway?
Hmmmm
It has stuck at around 3 to 5 kB/s until about 4 - now it is clocking along at around 100 to 200 kB/s
If you want me to download off peak, why throttle me during off peak?
Sorry - to answer your questions, other protocols are fine, and I am on - can't find the gateway, how do I do that. I think I need the user tools site, but can never find it on the portal - why is it not made more prominent.
Mand
Looking at these packet drop graphs you can see that at 4pm the rate limits kick in on Plus, and the number of Premier packet drops plummets.
The performance you were seeing off peak shows that you are not being throttled, but that a large amount of users are using interactive traffic, and there are numerous drops on non-interactive traffic as a result.
Zathras
thanks
OK - Im back.
You stated that the slow download until 4 would be due to throttling kicking in at 4 on BB+?
Can anyone then explain why header download is MUCH slower than body download - even before 4:00?
OK - A week on.
Anyone from plusnet (or anyone who knows) who can answer my question above, would be much appreciated.
Plusnet Staff
Plusnet Staff
Most likely because you're downloading headers using one thread but bodies using multiple threads. You might want to try a site like binsearch.info to create NZB files instead of downloading headers.
Thanks for the suggestion. I'll look into that.
