slow !! 26K connection is faster than me at present
doomreaper
yes its true, all day i have been on my 8meg line and runnign slower than a 26k connection.. OUCH!
help i need a speed rush
deekay
For weeks now, I have been getting download speeds in excess of 750KB/s, but this afternoon it's got slower and slower until it is now crawling along.
So, I have just done two Bandwidth Speed Tests. The first gave me a download speed of 27.13KB/s and for the second, it had dropped to a speed of 7.33KB/s.
I've not changed anything here and the computer and router have been on all afternoon and most of the morning.
It would appear that I am not the only one with speed problems today.
Hoping things are back to normal tomorrow!
Keith
rtc
Mine has been that way for three days now, I usually get 8mb reliably.
Now 250K Sad
Plusnet Staff
Plusnet Staff
Are you all on LLU? You can check by going to
http://usertools.plus.net/@gateway
If so there's a similar thread over in the PlusNet forum about LLU speeds that we're currently looking into.
Can you try the following test login:
username: testing@dslconnect.co.uk
password: testing
and try this speedtest while logged in with that:
http://speedcheck.ispconnect.co.uk/speedcheck/
and from there raise it as a fault via the fault checker (under connection settings on the left) and we can look into it for you.
doomreaper
cheers, yes i am on LLU, no offense but i had been checking all day on F9 server status and there hasn't been a mention of any problems, now if this is just LLU and as such dosnt get mentioned in the 'normal' server status for broadband, might it be worth starting a LLU server status section ?Huh
deekay
Yes, I am on LLU.
I logged off and tried logging back on again using testing@dslconnect.co.uk as the username and testing as the password, but it said invalid username or password and wouldn't log in.
Am I doing this incorrectly?
Also, where do I enter the http://speedcheck....... URL while logged into the portal. I've never seen anywhere to do it.
Keith
deekay
Update! Success!!
I have just done a normal Broadband Speed Check.
Speed is back up to 6.35Mb/s and my download speed is 812.49KB/sec.
So my speed is now back up to normal. Cheesy
Many thanks.
Keith
doomreaper
mine also, 7.5meg line capacity .. TY Smiley
deekay
Sent at 3:55pm.
My speed has gone right down again from the 6.35mbps I had this morning.
According to the Force9 Broadband Speed Check, it's now 175.10kbps and the download speed is down to 21.89KB/sec.
Sorry, but I still can't log in with username testing@dslconnect.co.uk and password as testing, as suggested by dtomlinson, to do the tests.
Cheers
Keith
My speed is abhorrent also mate. I'm currently downloading about twice the speed of dial-up so i'm leaving F9. Hopefully Virgin will get me up to a decent speed (and keep their email servers secure!!). I really think ISPs should be held 100% accountable for their service. If you buy a nice looking jacket and it falls apart the shop will refund you. Not so with ISPs it seems, something wrong there :-(
Plusnet Staff
Plusnet Staff
Looking at the line speed history from BT your line resync'd at a rate of 160kbps around 19/07/2007 05:03:46. This will have caused the throughput rate on your line to be decreased to 135kbps and it will only increase one the line has sync'd at a stable higher rate for 3-5 days.
You can check the throughput rate by running the BT speedtest:
http://www.f9.net.uk/support/broadband/troubleshooting/bt_speed_tester.shtml
Problems like this are often caused by incorrect wiring or filters, this is worth a read:
http://usertools.plus.net/tutorials/id/13
If you can find the cause and the sync speed goes back up again as I say it will take 3-5 days for your throughput speed to increase.
