sllooowwwwwww
sllooowwwwwww
Hi Guys,
Things seem to be running really slow today, is there still a problem with the ADSL service?.
Cheers
Plusnet Staff
Plusnet Staff
sllooowwwwwww
There's no outstanding MSO's and all the pipe graphs look OK. I recommend disconnecting and reconnecting and rebooting your for a start to see if that makes any difference as it will re-establish the connection.
If that doesn't resolve the issue take a look at
http://cgi.support.plus.com
as there are a series a tests you can do/check.
sllooowwwwwww
thanks for the reply,
it would seem the problem is not at Plusnets end Smiley, i was just unlucky enough to be trying places that route through nildram (who are having issues at the moment).
Cheers
Adam
sllooowwwwwww
Like being bought by Pipex. Cry
Eric
