routing issues - any progress?
Robtheplod
Hi All
Is there any progress with very slow routing between nodes when they connect to the same plusnet gateway? - ie RDP etc is diabolical if you happen to connect to the same plusnet gateway as your destination....
many thanks!!
James
Not that I've heard of, but I'll see if I can get any information about this.
Robtheplod
much appreciated as it's a real problem for our clients as they/we have to reboot routers until we connect to a different gateway...
Robtheplod
any news yet James as VPN/RDP over plusnet network is not really viable at present...
James
Hiya,
Sorry for not getting back to you sooner. This is awaiting a rollout of a fix. I'll let you know when I've been informed of a timescale.
Can you also update the pugit item when it does so we know when to test it.
Robtheplod
thanks for the update - keep pestering them as i currently have to recommend one end of the link to be at another provider to ensure it works!
James
We're expecting a fix to be rolled out today.
James
Ah sorry - We're doing this for business customers today. More details on residential customers when I have it.
