relay.plus.net
relay.plus.net
hi
we're in the early stages of fault finding, but it looks like relay.plus.net may be responsible for repeatedly sending the same email over and over again on occasions - is anyone else finding this Huh
relay.plus.net
Another user was reporting this over the weekend;
http://portal.plus.net/central/forums/viewtopic.php?t=43858
http://portal.plus.net/central/forums/viewtopic.php?t=43829
I suggest raising a support ticket.
Chilly
JonathanW
relay.plus.net
I'd say raise a support question as well, including as much detail as possible about what you're seeing and also headers of any affected emails. This should then enable the support team to resolve your issue swiftly.
Pathfinder
relay.plus.net
Yes Im still getting repeat emails. This has been going on since last Friday.
