regrade
regrade
hi, i put in a request for queue jumping to regrade, i have done speed tests on 5 different sites and they come up with speeds of 5-8mb, but my modem in still syncing at 2272? any help plz
Plusnet Staff
Plusnet Staff
regrade
Sounds like a problem with the speed test or maybe something on your system that's causing them to show the wrong speed. If your router is still showing 2272kbps then there's something wrong somewhere.
The queue jump and all regrades are being processed as quick as we can, but it's going to take time because we are limited to how many are done each week by BT Wholesale. Some of the queue jumps were done this, there'll very likely be more next week, fingers crossed your's will be amongst them.
regrade
Hi Dave... I have been on max for 4 days and my router says 8128 down 448 up but the link on Pn says 2000 still, any ideas of the problem.. Everything is sycin ok
stats as of 10.30pm were
noise margin:26 up 8 down
output power: 10.5 up 20 down
attenuation: 18.5 up 29 down
these have rarely changed if any at all
