referral values on portal
ukbrown
Not worth raising a ticket for. Mine is howing £4.00 exactly double what it should be.
francoise-hardy
So is mine. Must be 'added value' from f9!
Oh well, nothing is ever perfect.
robinh
Yes, I raised this before (see here). As you can see from that thread, Jon Whiting agreed there was a problem and he was to take it further.
Like some other problems on the portal, it has returned.
JonathanW
Yeah, its something that our developers are aware of, though it's been classed as something minor so they're working on more important things at this point in time. The correct ammounts are shown under the 'Current Referrals' section of the portal, if you really want to know how much you're saving.
