"Surf" setting in Connection settings
Has anyone actually found the "Surf" option in the Connection settings control panel to work?
I've turned it on and re-connected. My BitTorrent speeds are 15KB/s same as before (Broadband Plus).
Or is the idea not to block P2P, but to throttle it to Plus speeds for Premier and PAYG customers :?:
craigbrass
The idea is to totally block P2P applications and it worked fine for me when I tried it a few months back. Submit a ticket to PlusNet if your having a problem with it and they should be able to sort it out for you.
Were you using default p2p ports when it worked for you?
MrToast
Re: "Surf" setting in Connection settings
I've turned it on and re-connected. My BitTorrent speeds are 15KB/s same as before ... :?:
Not tried it myself, but I wonder if it takes time for the setting to promulgate the system.
Have you tried a further disconnect and re-connect now that its a while since you changed the setting?
I did turn my PC off for an hour after activating "Surf".
My torrent speed just went up to 180KB/s - I'm inclined to leave "Surf" turned on!
It dont work for me. limewire still works!
Well with me I would leave surf enabled and ban all p2p ports on the router. :lol: Get everyone brassed off and unable to connect to limewire kaazaa etc Wink A few months, I was on a PAYG account, my brother wanted connect to limewire and leave it on all the time :twisted:. So I banned him and he was totally brassed off Wink
The thing is, p2p ports are user definable. You could block the default ports in your router, but the user can still change the settings.
Yes, but i the user resets router/modem without knowing the router password, A hardware reset loses all settings inc username and password. So the user would not communicate with the intermet without calling CS.
But a 10 sec power reset keeps all settings . As my modem is seperate from my router, my broher did a hardware reset and I found out IP addresses changed to different users. Evil
But he was brassed off when he carried out a 10 sec reset, as I configured the router to ban all p2p connectivity and other computers to my network. :twisted:
