problems with online
hi,
just for my friend. he sign up for plusnet last Sept, throught online is everything ok so far BUT last week wont through online, already autoconfigure, did try username and password but nothing happened. What Happened, i know your problems with Email and Webspace problems but?
im grateful if anyone help me for my friend.
cheers
Hi geridunko
Does yer friend have a "user" name could be helpful !!!!!
Wink
ok
its blunden5 Smiley
they always say its your fault/check sign up and go back 2 bt]they say its never there problem?[i thought if i sighned up i.d get help/NOT]DONT TOUCH MOVE NOWWWWWW.
Miffs,
Your comments are not exactly helping the problem.
geridunko,
Have you double checked the settings and that no-one has changed anything since then? Don't forget all usernames and passwords are case sensative too.
Chris
ok ill find out.
cheers
if still problems, ill be back ok
Moderators note by John (johnessex) Quote removed. Please do not use the preceding post in its entirety.
i do try throught with username and password for my friend. But nothing happened with online.
he already sign up for plus net free online (pay as go) last sept til now!!
what going on?
username is blunden5
i know i cant show anyone his password.
im used plus net for near 2 years! i have noproblems with Plus Net but not my friend!
Thats why my friend would like follow me because plus net is best isp!
help?
Sorry, are you saying a PAYG account created in september isn't working?
Has the account actualy been used in that time?
If not, then it has likely been diabled due to the amount of time without activity. I sugest phoning support, who should be able to reactive the account.
Alternatly, signup with a new username.
ok, so have to close account? then sign up again for new one
or
do sign up again for new one?
let me know
cheers
As Philip posted, just call support and ask them to reactivate the blunden5 account.
If you don't want to do that then you can create a new account for your friend.
The choice is yours.
ok,
i need close first account, what do i do with close account? Sad
already signup done.
If the first account was a PAYG account, then there are no subscription charges.
You can simply ignore the account, as there is nothing that can truly be closed on it, other than deactivating it, as it is likely already done.
ok, already signup, and got plusnet free, so i would like know which i need non-bt line or bt line for auto configuration for Plus Net free
im grateful if let me know.
cheers
lhorwath
You can use any line to connect with us via the PAYG accounts (ie 0845 nuumbers). However for ANY of our other accounts to connect to us, you must have a BT line.
ok i did everything online, signup account, so on for my friend, its nothing happened, his pc wont throught online, his phone line is fine, his used aol online is fine but no more with aol, now signup plus net but now problems with line or plus net free, i dont know what i do! Sad
is it very very busy line for plus net free?? :?
Anyone help me to sort out my friend (username is blunden05) for through online please!Sad
cheers
