postmaster account
pennbank
postmaster account
Please, do we still need a postmaster mail box, now plus net have created a username@username.plus.com account as the default mail box ?
Plusnet Staff
Plusnet Staff
postmaster account
You don't necessarily need a seperate postmaster mailbox but you do need to continue to receive mail sent to the postmaster address. So you could instead add it as an alias to which ever mailbox you use. That's probably the easiest thing to do.
pennbank
postmaster account
Many thanks for quick reply
Plusnet Leader
Plusnet Leader
postmaster account
No problem.
Give us a shout if you have any more questions.
Alistair
postmaster account
I remain puzzled!
I recently switched off the "catch-all" as recommended to minimise random SPAM, and I note that PN has automatically added an Alias of "Postmaster" - but linked to username@username.plus.com, the address that I thought would now be "blackholed". I now only monitor my "named" mailboxes.
Have I misunderstood something about the catch-all?
Alistair
Plusnet Staff
Plusnet Staff
Fixes: 159
postmaster account
A catch-all will basically receive anything@username.plus.com
When you turn off the catch-all there is a postmaster address created if you do no already have one in place, this is the address we use to contact you on.
 Chris Parr
 Plusnet Staff
Alistair
postmaster account
In that case I would prefer to re-direct the Postmaster Alias to a "named" account - but there is no option to do so!
Or is it a PN requirement that I monitor the username@username.plus.com?
Alistair
thehatman
postmaster account
Isn't it in "Alias", then "Add Alias" ? Then after you've done that delete the separate postmaster account. Is that right PN?
Liam
postmaster account
You need to add the postmaster alias before turning off the 'catch-all'.
Not ideal, but if you re-enable the catch-all temporarily, it will then allow you to create the postmaster alias against a different mailbox. Then, when you turn off the catch-all again, it will stay attached to the mailbox you chose.
Hope that helps!
Gilles
postmaster account
I suspect anyway that PN will have to stop using the postmaster address and only use the address in the user settings (set for this very administrative purpose).
The reason is that due to the ongoing SPAM issue it is clear that a number of domain/username have been leaked. And once you have this information you don't have to be very clever to start sending SPAM to:
postmaster@leadked-username.plus.com
Unless PN start renaming all of the user account names... That could be fun Sad (although from a security point of view that probably would be the most reasonable thing to do).
Gilles
postmaster account
Admittedly someone scanning the PN forums would be able to gather quite a lot of username. And with this info it would be relativelly easy to build SPAM attack on addresses like:
postmaster@domain.plus.com
domain@domain.plus.com
Hum... Not very good. Personnaly I am not collecting email anymore from these...
Alistair
postmaster account
Hope that helps!
Have now tried that - sadly the postmaster alias remains without edit or delete option.
Do I have to raise a ticket to change it now?
Alistair
Malwa
postmaster account
Hope that helps!
Alistair
This isn't an ideal solution but I was playing around just now and found that if you go to redirect you can redirect the postmaster mailbox to any of your other PN mailboxes. It seems to work because I just sent my postmaster mailbox an email from my hotmail account and it turned up in the mailbox I had redirected it to.
Paula
<typo edited>
Alistair
postmaster account
Thanks for the work-around Paula!
postmaster account
The issue was also noted here.
