possible for plusnet to change my IP address
Hi I have had some problems with hackers is it possible for PN to change my Ip address for me ?
If you visit Link:Contact us _ Raise New Query - Follow the wizard through Tech Support (Except Connection problems) - Static IP's - Change Static IP and explain the circumstances, support will take it from there.
Hope that helps.
Fixes: 8
What happens to the old IP? Does it given to the next innocent that comes along?
I can't believe this is the best way to deal with hacking attempts.
[Moderator's note by Tom (tomspcs): Previous post quote has been removed.]
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
I am not saying that it is John, but its up to the abuse team to take it from there.
For the benefit of the OP, I am not saying that your IP will definately be changed but that is the route to take to get it actioned.
