pop and mozilla thunderbird
i am unable to send email via thunderbird i am asked for the password and it rejects it, i have checked all the settings but i still cannot send any email, i can receive email so i know my password is correct anyone who can help out there
Blackthornehous
I had the same problem which was easily resolved - for me at least! Have a look at the Thunderbird knowledge base, http://kb.mozillazine.org/Cannot_send_mail with reference to the paragraph beginning 'user name and password' and SMTP authentication. I found that unchecking the box as suggested solved my problem. I think it also suggests somewhere to check that your firewall is not blocking outgoling messages. Hope this helps.
Tim
thanks for that its done the trick
