plusdsl2 problem??
geoffers
plusdsl2 problem??
Hi
Was there a problem with the plusdsl2 network this morning - I was unable to connect, but when I reset to plusdsl I connected OK
Cheers, G
plusdsl2 problem??
Same here!
plusdsl2 problem??
plusdsl2 connects you to the RIN network which a trial network by BT Retail and is different to using plusdsl so there may have been (or still is) a problem with RIN.
zpeterk
plusdsl2 problem??
Not working for me either
Interestingly went I connect to plusdsl I get redirected to the "Increase your Data Transfer Watch amount to keep browsing" page which I have not exceeded, so I can't get to any website apart from plusnet
Perhapes I should raise a ticket
Stitch626
plusdsl2 problem??
Still not allowing logins and nothing posted on the service status page.
Anyone at Plusnet today to look into this?
hitachi
plusdsl2 problem??
Working fine for me.
plusdsl2 problem??
Hi there.
I am experiencing a similar problem from home. The CSC are aware and are investigating.
We're collating examples now and trying to identify a pattern. We'll update as and when we have further information.
mcgerard
plusdsl2 problem??
I have this problem too. Posting this via dial-up connection.
plusdsl2 problem??
Mand
plusdsl2 problem??
You can monitor the priority 1 problem here.
In the meantime, switching back to plusdsl.net in your modem/router should resolve the issue for you without the need to use dialup.
kitz
plusdsl2 problem??
Mark / Mand
Is this related to the RIN problems I reported via PUG on Thurs night -
Ive posted a load of stuff up in PUG about it and some diagnostics that I did that night.
Plusnet Staff
Plusnet Staff
plusdsl2 problem??
Should be fixed now if you can give it another try, just about to update service status.
