p2p
p2p
Why can`t i download p2p as in torrents etc. I used to be able 2. Is it the low usage no p2p IP address per chance or just me. Have had the same account for about 3 years on ADSL statup or something like that. can you help
Plusnet Staff
Plusnet Staff
p2p
Is the account type Home Surf? If so then that would be the reason as P2P isn't allowed on Home Surf accounts and never has been. If you want to use P2P then you would probably best upgrading to Broadband Premier.
p2p
yes its home surf. I was using other p2p before and they worked. Is it some change due to reorganising of the different accounts and if i upgrade to premier would this sort the problem
Ken
Plusnet Staff
Plusnet Staff
p2p
P2P has always been blocked on Home Surf, it's just our systems are better at it than previously. If you upgrade to Premier then you would be able use P2P.
p2p
After a fashion, that is, providing you're not interested in using it at peak times when everything slows to a crawl and connections get dropped.
p2p
Has P2P on Premier improved as a result of the new service improvements? I'm on BBPlus at the moment and want to know whether it's worth upgrading.
Dan
p2p
I've just had it confirmed to me that emule / ed2k is err.. incompatible with the new traffic management. (can we have an official announcement please f9?)
Torrents seem to work ok on premier, but I like to have a choice, so I've just asked for my mac key.
Took nearly a month to get an admission from f9, now they want a months notice :lol:
p2p
p2p
