p2p throttled at 10%
Finally found out that p2p is throttled at 10% (I wonder what % emule is throttled at??). The information was from AG so I don't know if this is TRUE
I presume this is off-peak? and during peak times the % rises?Huh
Hi
i too saw that on Ag but didnot think much about it until i read your post i think most people like myself thought it was throttled By 10%,
But if its throttled At 10% then thats why its so slow
thanks
Maybe we could get a clear answer from CS
emule is p2p. Do u mean NNTP?
LiamM
P2P is NOT throttled at 10%. I had 4 torrents cruising at 230k/s last night.
Re: p2p throttled at 10%
What / where / who is AG ?
Hi
Mm it says p2p , mind you i reread it again and the way its written i spose it By upto10%,
english never was my strongpoint along with other subjects Shockedops:
thanks
Fixes: 57
I assume this is the post ADSL Guide but in fact it states
Peer to peer on premier is is throttled up to a maxium off 10% thats all so its not being throttled to death, its not in breach off the original intent as we have always said we would protect our network. We are not doing any thing to your peer to peer, i my self have a premier acocunt and use peer to peer and have no problems with the service what so ever
Plusnet Staff
Plusnet Staff
The quote means that the management should reduce speeds by a maximum of 10%, not to 10% of the maximum speed.
martinfamily - what torrent client are u using? I'm finding the ed2k network a bit pants these days
Hi martinfamily
Are you sure its kB and not kbps Cheesy
thanks
Thanks Dave for correcting that Smiley
Is BT and emule throttled at the same rate? IS so, how come emule speeds on average is 10kbs (My speeds never seem to hit 50kbs and if it does it does not last long)
ADSLGUIDE
Ben_Brown
It isn't a percentage, and depends on many factors. The agent who said 10% meant that it is shaped by a maximum of 10%, which is a rough figure but may not always be accurate.
geraintmx333 - I'll comfirm that torrents work at 230kbytes/s during off peak.
On peak varies all the time, day to day. anywhere between 30~180k on avg
Mine throttles down to 10% of the maximum speed. I rarely get past 10kB/s and I never get past 20kB/s using Bit torrent. Ugh now im only getting 20kB/s from http.
