outlook express wont open?
owlguard
Hi,my outlook express wont open sometimes,i dont know if its to do with spam im getting recently but ive just shut pc down and restarted and its working again.I couldnt get onto internet for about a week and a half and when i got back on with my new router installed,outlook express wouldnt open,i put it down to having to go into plusnet mail and delete around 250 spam messages,does this problem have any baring on the situation with regards to amount of spam emails.Huh??
Would appreciate any thoughts on this problem.
regards ray and up the owls.
Fixes: 57
I have had the odd occurrence of this and funnily enough although it wasn't apparently running when I opened Task Manager it was showing up as a running process.
Usually closing the process from Task Manager and trying to start Outlook Express again worked
owlguard
Thanks for that jim.
regards ray
