ok sync rate question
i have managed to get my router to sync under the 8128kbps its been on for the last 5 days
im one of those stuck waiting for the stable rate to change
is it worth leaving it synced at what it is now in the hope it might change my stable rate
or should i put it back to the max
dont want to affect the final outcome of the tests
1 REPLY
mitchell20
I've also just managed to get my sync speed down from 8128 to 5920 by plugging in a phone into an unfiltered socket.
Nothing appears to have changed here either though. I'm also not sure how long to leave it sync'd at a lower speed for :?:
I'm going to un-plug the phone and re-sync at 8128 again here.
