ok no im lost my router sync's at 8128 kbps
ok no im lost my router is sync at
Modem Status Connected
DownStream Connection Speed 8128 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
speed tests show same speed
02-05-2006 19:07:33 1903.1
02-05-2006 18:46:53 1915.4
02-05-2006 18:44:42 1912.5
25-04-2006 20:35:54 1919.1
22-04-2006 10:34:25 1926.8
22-04-2006 07:16:03 1931.5
i can upload at 48KB/S
so i phoned pn c/s
about the speeds that im downloading at
they say i not even been put forward for regrade yet is this possible
i have not recieved any email to say regrade complete or that i been put forward
if the router is sycning at 8mb surley it means i been regraded
Congrats your on MaxDSL prepare to watch your connection drop like hell for 10 days Tongue
You have, ignore the CS agent - He knows NOTHING
Wink
Give it 10 days and everything should be sorted
Last test for me showed 1.8mbs, after migration this afternoon 6.6mbs Smiley
migration?
Not a very helpfull answer above :roll:
Yes, you have been upgraded to DSLMax but BT may not have informed PN yet hence the CS agents reply.
Anyway BT have a bug in their system which fails to detect the higher sync speed so you will remain limited to 2Mbs until the new sync speed is recongnised which should be in 3 or 4 days. linky
All you can do it wait.
I'm on 8.1 according to my modem but getting 1.2 Mb at the moment!
And this is outside the 10 day period!
thanks for that petervaughan
and thanks to the otheres for speedy replies
lets see what time brings
holdtight
A beard Wink
Took twelve days for max to kick in here not sure if its finished settling yet or not
