noisy phone line
noisy phone line
can anyone advise me what to do with a noisy line? Iam using the filter that was supplied with the usb modem.
RE: noisy phone line
If you have a noisy phone line first establish whether this is down to the filter/adsl connection are the actual line this can be done by checking to see if the noise is present when the adsl equipment is installed to the line are if it is always present if it is when the equipment is present and active check to make sure that your filter is in the correct location and replace with another in necessary.
However if the noise is always present then you will need to contact BT on 150 and raise it with them.
Regards,
Lee,
| Lee Mckenzie...................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
Make sure that you have a filter on any other extensions also. I found that I had noise when I left one of my extensions unfiltered.
