no route to file vault ?
can't find a route thru the portal to the file vault ? or is it discontinued ?
also where is the members web sites page ?
is there a secret portal within this site that i am not finding ?
advise please-------time is upon us.
IIRC it was removed a while back. All of the files where upto 4 years out of date so it was useless. PlusNet dont have time to administer it and the usergroup was reluctent to take over.
Chris
so I'm not going mad or blind after all.
many thanks
Is there anything similar?
Used to find it useful for things like CuteFtp etc.
Not so much for any specific file, but more in that things that were there tended to be well known about by peeps in these forums?
Or have I got confused with something else? :?
It's just as easy these days to do a search on one of the engines (google for instance) and come up with what you need in the way of software.
Its all out there. All you have to do is look for it. Smiley
