newsletter 10 Content links
xon
Hi All,
Oops! It seems that each of the Contents links contained in newsletter 10 are returning
https://webmail.plus.net/images/blank.png
You guessed it correctly you get a blank page! Other links in the newsletter seem to be working ok.
If at first etc etc....
Regards
Hi there.
The content links should bring you to the relevant article in the newsletter. These were tested prior to sending and I am currently unable to replicate this internally.
Can you let me know what mail client you are using?
Additionally I'd love to hear from anyone esle experiencing this issue.
<<Edit>> Cancel the daft question. I can see you are using Webmail.
We'll investigate this further.
Hi there.
We have replicated this and are currently investigating the cause of thsi issue.
Please accept our apologies for any inconvenience caused.
Hope you update your test scripts to include Webmail in future :lol:
Ok we've identified the problem.
Squirrelmail doesn't like the # which is used in the anchor links. We are trying to identify a fix for future newsletters or failing that we'll simply have to remove the anchor links for future editions.
xon
Thanks for your efforts to sort this out.
It is odd that the other hyper links in the newsletter, with the notable exception of http://invalid-stuff-detected.example.com,all work well and point to a variety of different web locations but the properties of the Contents hyper links are not working correctly because their properties point at:-
Almost like >/dev/null
However Plusnet are undoubtedly in the best position to judge how to fix their own issues.
Regards
