netgear router problem
hi
am fairly new to this... and very new to wireless routers!
Am tryin to set up netgear router, get to where I need to connect through browser to routers address and I just keep getting the std dial up box askin for name and password of isp...
any ideas?
In IE, go to tools, Internet options.
Click the connections tab and then select the radio button that says "Never dial a connection".
This causes IE to look to the LAN for a connection.
If you have Windows 98/ME you may need to reboot at this point.
Open IE and type 192.168.0.1 into the address bar.
Enter "admin" & "password" for username and password and you're in.
Sorted
Andrew
Thanks mate, giving this a go!
When you are in just select the option to let the router auto detect the ADSL type and you will then be presented with two boxes to type you broadband usename and password into.
Enter these, click ok and bingo you're online !!.
Make sure you encrypt the wireless connection.
Andrew
