my usage
my usage
my usage shows 240mb of broadband phonecalls.
any ideas how this got there given that i have no idea what this is ?
do you think they are confused with the 240mins of waiting i have done on their support phone line this month?
my usage
Maybe it's a hint; they're saying you'd have had a better experience by VOIP'ing a friend on a decent network to read the internet to you.
my usage
It relates to a system called VOIP, (Voice Over IP) which basically means you can use your PC as a telephone to make calls over the internet.
Here is the PN Plustalk (VoIP) homepage, which contains all the FAQ's and info to get you started (should you want to get started Wink )
my usage
the thing is - i dont have voip and as far as i know there is no special batphone attached to my pc - i cant make calls but myusage says different?
my usage
barkerfamily,
You're not alone. Check out How reliable is the usage monitor? and The New VMBU must be Fiddled.
If I'm to believe my usage record, I used 740kb last month on Broadband phone calls. To date this month I've used 197kb! Of course I don't have a broadband phone, and wouldn't know how to set one up if I had.
Cue someone to drop by and enlighten us with talk about "network noise" etc.
But please keep posting ... I thoroughly enjoy your comments. You've got to see the funny side here, otherwise you'd despair and get carted off to the funny farm. Smiley
DT
Fixes: 133
my usage
As I write this reply surrounded by men in white coats :lol: there is another thread just started on this here:
http://portal.plus.net/central/forums/viewtopic.php?t=43145
Forum Moderator and Customer
my usage
colhindene,
Fabulous! There we go again ... more "noise". I'm convinced "barkerfamily" is solely responsible, impatiently kicking the bucket during that long wait on the phone on Wed evening (see please call back later) .. no doubt the resulting noise travelled down his router and got logged onto your account! SmileySmiley
DT
my usage
BROADBAND TELEPHONE = A DABBLED TEEN HO PORN
Perhaps Plus.net are using anagrams to save your embarassment, don't try telling us you don't have at least 740Kb of A DABBLED TEEN HO PORN.
Andrew :shock: :shock:
Fixes: 133
my usage
I think it more likely that ADELE 'N BOB HAD NE PORT causing many more problems :lol:
But the answer probably lies here:
O, BEEN HANDLE PORT BAD!!!
Wink
my usage
VIEW MY BROADBAND USAGE = DAVY, A BIG RANDOM WEB USE
Regards,
Davy
