my 2 penny worth...
ipanda
my 2 penny worth...
surely, this is not "broadband"? is there a speed that is the minimum to be classed as 'broadband'?
thanks.
TheFixer
my 2 penny worth...
Apparently:
"The results of our tests show no fault with your broadband connection. Completed speed tests show that your connection speed is: none found
According to BT, this speed is within the limits of acceptable performance for broadband service."
Still applies!
You're lucky! Since yesterday I'm at this
my 2 penny worth...
Mine seems OK (here)
my 2 penny worth...
:shock: - Mod privileges
30.51 Mbps
Which means you can download at 3.81 MB/sec. from our servers.
53.3 kbps 56k Dial Up
64 kbps ISDN 1 Channel
128 kbps ISDN Dual Channel
460 kbps ADSL 500
920 kbps ADSL 1000
1840 kbps ADSL 2000
31247.1 kbps YOU
I though mine was fine - Here - But now I want some of yours.
my 2 penny worth...
The speedtester.bt.com says this for my first test, and then this for my second. Wink
my 2 penny worth...
You're a proper wind up merchant, James.. Tongue
jagger
Re: my 2 penny worth...
thanks.
400 kbps.
Fixes: 8
my 2 penny worth...
The generally accepted definition of Broadband is any thing which is faster than dialup or ISDN so that means faster than 128Kbps.
400K is the minimum speed deemed acceptable by BT for a 2MB or faster line.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
