modem cable
modem cable
does anyone know where you can get a longer cable than the one supplied to connected the usb modem to the phone spliter?! As I want to run a cable from the telephone line downstairs to my room?
modem cable
I have one here which I beleive is 10M (not sure, havn't used it in a damned long time).
However, you best bet is to install a wired extention, into which you plub your modem. Proivided you used any half deceint cable, you should be fine.
modem cable
ok cheers
modem cable
is it rj11 connections they use?
Ianwild
modem cable
That's right - RJ11 is the small plug that goes into the ADSL side of a splitter and is normally the same on both ends.
Regards,
Ian
modem cable
yer fought so just making sure cause ive found the cable now so wen it cums my problem will be sorted Cheesy
